hgandhi204
Aug 01, 2019Tutor
Connecting hard disk to Router
Hello All, I have just completed the setup of Orbi RBK 50 and 1 satelllite. I had ASUS router which had USB 3 and USB 2 ports through which I connected my hard disk and used it over the network. ...
Aug 01, 2019Guru - Experienced User
Orbi doesn't support USB drives.
You'll have to contact ASUS to see how they support and configure there router for USB drives. I presume if your wanting to use the ASUS as your USB drive support, you may want to configure that router for AP mode.
Retired_Member
Aug 01, 2019
FURRYe38 wrote:Orbi doesn't support USB drives.
https://www.windowscentral.com/what-devices-can-you-connect-netgear-orbi-rbk50-usb-port
- hgandhi204Aug 01, 2019Tutor
Yes, I was aware of Orbi not supporting USB drives, that is why I connected my ASUS router.
