hgandhi204
Aug 01, 2019Tutor
Connecting hard disk to Router
Hello All, I have just completed the setup of Orbi RBK 50 and 1 satelllite. I had ASUS router which had USB 3 and USB 2 ports through which I connected my hard disk and used it over the network. ...
Aug 01, 2019Guru - Experienced User
Not officially supported by NG.
- Retired_MemberAug 01, 2019
FURRYe38 wrote:Not officially supported by NG.
so only posts by you are supported?
- hgandhi204Aug 01, 2019Tutor
I didnt understand your question? ASUS router supports HDD, thats why I connected it to network switch through orbi
