hgandhi204
Aug 01, 2019Tutor
Connecting hard disk to Router
Hello All, I have just completed the setup of Orbi RBK 50 and 1 satelllite. I had ASUS router which had USB 3 and USB 2 ports through which I connected my hard disk and used it over the network. ...
Retired_Member
Aug 01, 2019
hgandhi204 wrote:Hello All,
I have just completed the setup of Orbi RBK 50 and 1 satelllite. I had ASUS router which had USB 3 and USB 2 ports through which I connected my hard disk and used it over the network. I know there are different reports regarding the USb functionality on the Orbi router.
I currently have a network switch which is connected to Orbi router and many devices are connected to the switch including my ASUS router.
My question is that when I connect my HDD to the ASUS router I dont see it on the network probably coz of different IP address of different routers? or soemthing. I would like to access the hard disk on Roku and android TV which do not detect the HDD on the network.
Any solutions? help or ideas is very much appreciated
Thanks
HG
Are you still using the ASUS router with the Orbi ROUTER??
hgandhi204
Aug 01, 2019Tutor
Yes, I have connected my ASUS router through the network switch which gets its connection from Orbi
