pskerry
Sep 20, 2017Tutor
Connecting iPhone to 2.4 Ghz band ?
I need to perform a one-time setup on my network between my iPhone 6 (app) and a weather station. The Weather Station only utilizes the 2.4g band. Any Ideas? thanks, Pat
Hydro130
Sep 20, 2017Luminary
Have you actually tried the setup yet (assuming your iPhone is on 5Ghz)?
I'm not familiar with that particular weather device, but I have several 2.4-only devices (printers, monitoring devices, etc) on my network that I can access & manage with no issues via my iPhone when it's connected to 5GHz.
martyfp
To get it onto 2.4, you could try to move the phone some distance from the Orbi, it should automatically drop back to 2.4GHz. (You can check this from the orbi attached devices page if you're running 2.0 firmware). When you move back towards the Orbi, the phone will normally stick to 2.4GHz unless you disconnect/reconnect to wifi.
- martyfpSep 20, 2017Luminary
I actually needed to do the opposite trick to get My Samsung R1 speakers to connect to 5GHz instead of 2.4 (it seemed to always adopt the band that the phone was on when setting it up via the app).
