pskerry
Sep 20, 2017Tutor
Connecting iPhone to 2.4 Ghz band ?
I need to perform a one-time setup on my network between my iPhone 6 (app) and a weather station. The Weather Station only utilizes the 2.4g band. Any Ideas? thanks, Pat
rhester72
Sep 21, 2017Virtuoso
I have 7 Protects and all have connected (and remained connected) without issue.
Rodney
NestoMS3
Sep 21, 2017Tutor
I used this guide to create seperate SSID's for the the 2.4 and 5ghz channels so I could pick and choose. Works flawlessly
https://www.reddit.com/r/orbi/comments/5svxmy/howto_configure_different_ssids_for_24_and_5ghz/
FYI, if you do the above, do the router first, then the satellite (yes you have to do it on both) and make sure the SSID names are identical.
