sdcycling
Dec 07, 2021Aspirant
Connecting Netgear Orbi RBK50 to Nokia BGW320-505
 I am stuck and I need some help.  I turned off the 2.4GHz and 5GHz Wi-Fi radios on the BGW320. I enabled IP Passthrough on the BGW320 with DHCPS-Fixed.  I manually entered the MAC address of the Orbi...
- Dec 07, 2021
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/OrbiYour ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Thank you.
Dec 07, 2021Guru - Experienced User
Couple of options,
Thank you.
