toots45
Jan 04, 2022Aspirant
Connecting new satellite to existing RBS50v2 router
Hi there - i need some help pls! I have prevsiously purchased and installed a RBS50v2 router with one satellite based on the ground floor. The satellite is located 50m away in an outbulding on the gr...
Jan 04, 2022Guru - Experienced User
what firmware is on the satellite and what version is on the router?
Have you tried hardwiring the satellite in for initial setup?
- CrimpOnJan 04, 2022Guru - Experienced User
My approach is to sync new satellites in the same room as the router (temporarily). No huffing and puffing up and down the stairs to press sync buttons and look at light. Once it has connected successfully, then I move it to the desired remote location.
The new satellite came pre-programmed to link with the new router. Perhaps it would be helpful to do a Factory Reset on the new satellite before attempting to 'sync' it.
- toots45Jan 05, 2022Aspirant
Thanks for the responses - much appreciated. The factory reset on the satellite seems to have done the job, but i'll await my kids gaming in the attic to really test it!
- FURRYe38Jan 05, 2022Guru - Experienced User
