Gurvy
Sep 03, 2019Aspirant
Connecting Nighthawk 7800 and Orbi
Hello, Have this set up: Cable Modem>ethernet to R7800>ethernet to Orbi RBR50 router>ethernet extended as mesh to 2 other RBS50 Satellites and wirelessly to Orbi Outdoor. R7800 also has my differe...
Gurvy
Sep 04, 2019Aspirant
Thanks for the input. Will the change to AP mode recduce my ability to have the mesh network work to it maximal capacity? I have 2 interior satellites that are connected by ethernet and 1 outdoor orbi that is linked on wifi connection - will that be affected at all?
Sep 04, 2019Guru - Experienced User
Nope. the orbi will still act in mesh network capacity and work as just wireless access points (can still use the ethernet ports as well).
here's the list of things that'll be disabled within orbi. However, it'll still function on your R7800 so its a bit of a moot point.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
