ReallyStumped
Sep 16, 2022Aspirant
Connecting Orbi rbr40 to ATT fiber modem BGW320-500
Just had ATT fiber installed with a BGW320-500 modem. The installer tried and I hvae tried to connect it to my Orbi RBR40. How is this accomplished? I have read it can only be done using AP mode, w...
Sep 16, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
You can try option #2 first...
ReallyStumped
Thanks, I'll give it a shot.
- FURRYe38Sep 16, 2022Guru - Experienced User
đ
