weldjame311
Jul 24, 2020Aspirant
Connecting Orbi RBR50 to existing Orbi AC3000 network for configuration
Recently was given a RBR50 router. Tried to hook up on a newly installed router. Saw the SSID but could not connect in order to configure. Would like to see if I need to do a factory reset. Can I...
- Jul 27, 2020
Thanks for all the support.
In the end, the solution was to disconnect the existing Orbi network and substitute the RBR50 Mesh Router I received from my friend.
Took awhile plus resetting the unit to factory settings, but in the end I was able to get it to work. Now I will take it back into NYC and hope it plugs-and-plays. One of the major barriers was that new laptops do not make come with CAT-5 jacks built in. Connection with an ethernet cable might have made the reset faster/easier.
In the end, all's well that ends well. Thanks for the support. Orbi's are still the best.
weldjame311
Thank you for the quick reply.
Actually, what I am hoping to do is to test whether the "new/ord" router (SSID 97) A) can attach to the internet (when previously tried I could not get it to do so) or B) must be factory reset to allow me to confogiure it to connect to the internet (e.g., by removing some setting the previous owner forgot to remove before giving it to me).
In either case, once I have the "new/old" router configured (or not) I will disconnect it and take back to our city apartment (which has not Orbi at present.
Does this clarify?
CrimpOn
Jul 24, 2020Guru - Experienced User
weldjame311 wrote:Does this clarify?
Thanks for explaining. Makes perfect sense. So, yes, connect this router to any port on the base Orbi unit and it should connect to the internet. A "Factory Reset" certainly cannot hurt anything, and will clear out any settings that have been made in the past.
Good Luck
