weldjame311's avatar
weldjame311
Connecting Orbi RBR50 to existing Orbi AC3000 network for configuration
Recently was given a RBR50 router. Tried to hook up on a newly installed router. Saw the SSID but could not connect in order to configure. Would like to see if I need to do a factory reset.   Can I...
  • weldjame311's avatar
    Jul 27, 2020
    Thanks for all the support.
    In the end, the solution was to disconnect the existing Orbi network and substitute the RBR50 Mesh Router I received from my friend.
    Took awhile plus resetting the unit to factory settings, but in the end I was able to get it to work.  Now I will take it back into NYC and hope it plugs-and-plays.  One of the major barriers was that new laptops do not make come with CAT-5 jacks built in.  Connection with an ethernet cable might have made the reset faster/easier.
    In the end, all's well that ends well.  Thanks for the support. Orbi's are still the best.
