mirama44
Dec 25, 2018Tutor
Connecting Orbi router to a Nighthawk?
Hello. I'm sure someone may have already asked this but I could use some help. I am trying to connect my orbi router with a cat7 ethernet out to an outside building. I have the cable ran from house ou...
Dec 30, 2018Guru - Experienced User
Review these for configuring AP mode on the Orbi system:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
mirama44 wrote:
Helli,Hello, me again. I reread your post and you said to use WAN port on orbi router for AP mode. I'm not sure what that means. I have my internet provider cable coming into my orbi router into the yellow "internet" connection. I have my cat 7 in one of the Orbi's other connections running outside, underground in conduit about 150 feet to my outbuilding where my nighthawk router is located. I plugged the cat7 into the WAN port of my nighthawk router. I cant get internet. I plugged my laptop into the cat7 connector in the outbuilding and cant get internet. The other night you suggested to put orbi into AP mode. I put the orbi into AP mode but then I couldn't get internet anywhere in my house. I had to reset the whole orbi system and reset it up. I did retest my cat7 cable today and tester still reads that everything is good.
I was wondering was I supposed to put the nighthawk into AP, not the orbi?
Thanks for help!
ekhalil
Dec 30, 2018Master
ORBI IN THIS CASE CAN’T BE IN AP MODE.
PLEASE READ!
PLEASE READ!
- michaelkenwardDec 30, 2018Guru - Experienced User
PLEASE READ!Please explain!
- FURRYe38Dec 30, 2018Guru - Experienced User
Really.
- ekhalilDec 30, 2018MasterPlease read the posts above.
Orbi is the only router. The Nighthawk is to be connected (wired) as an AP to Orbi to extend the range in a remote building.
He has a problem in the cable that needs to be fixed. I think that’s the only issue now.
