mirama44
Dec 25, 2018Tutor
Connecting Orbi router to a Nighthawk?
Hello. I'm sure someone may have already asked this but I could use some help. I am trying to connect my orbi router with a cat7 ethernet out to an outside building. I have the cable ran from house ou...
Dec 30, 2018Guru - Experienced User
If the Orbi is acting as the main host router, then they can configure the NG router for AP mode and connect it to the Orbi router at the remote location. The NH router needs to be connected via its LAN port to the Orbi's LAN port, not the WAN port when in AP mode. This will work.
IF the NH router is the main host router, then the Orbi can be used in AP mode at the remote location or a satellite or a Orbi router in AP mode can be used at the remote location.
- michaelkenwardDec 30, 2018Guru - Experienced User
Yup. That's how I see it.
Choose one to be the router, set the other in AP mode.
As I said earlier, it is not clear to me which box is destined for which role.
If the idea is to have good wifi in the house, then using the Orbi as the router make sense. Then the Nighthawk goes in the "shed".
From what we read here, most people with an Orbi/Nighthawk combination tend to use the Nighthawk as the router, probably because it offers more control but the wifi isn't so good.
