Slosh104
Mar 04, 2018Aspirant
Connecting Orbi to Alexa
Alexa will not discover my Orbi. How can I get Alexa is integration with Orbi?
Slosh104
I have the Echo Dot.
Roamabout
Mar 04, 2018Luminary
So the echo dot gets configured via the alexa app on your phone/tablet.
You put the dot into config mode, connect to it over wifi with your phone/tablet and then go through the steps to connect it to the Orbi.
What part of that process is not working ?
- Slosh104Mar 05, 2018Aspirant
The Alexa app will not discover Orbi. The Wifi portion is working and Alexa is connected to the network via Orbi, but I want to integrate Alexa to turn the guest network on and off.
- RoamaboutMar 05, 2018Luminary
Slosh104wrote:The Alexa app will not discover Orbi. The Wifi portion is working and Alexa is connected to the network via Orbi, but I want to integrate Alexa to turn the guest network on and off.
aha. Have you added the Netgear skill (using the Alexa app on your phone/tablet) ?.
