GinaFitz
Aug 13, 2017Aspirant
Connecting Orbi to iAquaLink pool system
I am unable to connect my iAquaLink system to the Orbi network. I get as far as selecting the network and putting in my password. It just drops the network. I understand that the iAquaLink can only wo...
Bento78fr
Apr 30, 2018Aspirant
After years of frustration trying to connect my iaqualink module to my home internet, I tried everything, from constantly dropping Powerline internet to range extender, I was never able to get a solid connection with my pool on my iPhone until now!!!
All I did was repeating the iaqualink WiFi setup and then within the orbi app you can actually see under WiFi devices you iaqualink device but still can’t connect wirelessly, I then tried to change the device name from unknown to other and voila!!
I am now connected to my pool without Loosing the signal constantly.
Kmaan
May 24, 2018Aspirant
I just helped a customer last night setting up the aqualink to make a solid wifi connection to the wifi network using a wifi extender. The aqualink was the only device connected to the extender using 2.4 GHz and all other devices in the home are connecting to the home router either through 2.4 or 5 GHz. The home connection is a Netgear router and the extender is Amped Wireless SR20000G High Power Wireless-N 600mW Gigabit Dual Band Repeater and Range Extender . It would be wise to use an Android device and install the app to see if the connection drop is occurring there as well.(Trying to eliminate possible issues with the Apple device).
