GinaFitz
Aug 13, 2017Aspirant
Connecting Orbi to iAquaLink pool system
I am unable to connect my iAquaLink system to the Orbi network. I get as far as selecting the network and putting in my password. It just drops the network. I understand that the iAquaLink can only wo...
silver123
Feb 15, 2019Aspirant
As a quick safety precaution I unplugged the att router, orbi and sat then plugged them all back in and I believe that resolved it. I suspect the changes that impacted it were the following which changed them back to factory yesterday but even though the router did restart after the changes, I suspect unplugging / plugging back in got it to fully update the changes
| Backhaul Topology | |
| Enable Daisy-Chain Topology | |
| Backhaul Password | |
| Orbi can generate a new hidden password to improve security for its backhaul connection. | |
| WARNING: Generating a new password might cause the Orbi satellite to lose connection from the Orbi router. To reconnect, use the Sync button. |
| Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices | |
| Enable MU-MIMO | |
Enable Fast Roaming
Feb 15, 2019Guru - Experienced User
If you unplugged the Orbi and back in and previous settings were not saved, thats a problem. Any power OFF, unplug or just a reboot of the router, settings should persist thru these operations.
If this is happening on your system, I would try the following, manual FW re-load using a web browser and download the FW file for the router. Apply and after it's back to ready, factory reset and setup from scratch. Make some changes and test the persistence of settings after doing a un-plug and plug back in to power it on. If the settings are not persisting, then the unit would be faulty and you should ask about an RMA.
Backhaul Topology Enable Daisy-Chain Topology Backhaul Password Orbi can generate a new hidden password to improve security for its backhaul connection. WARNING: Generating a new password might cause the Orbi satellite to lose connection from the Orbi router. To reconnect, use the Sync button.
Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices Enable MU-MIMO Enable Fast Roaming
