Fiat500
Nov 30, 2022Aspirant
Connecting Orbi to network extender
HI, I have a mesh network, Orbi RBR50+RBK30 & still have some areas of poor wifi, ie in garage. Ideally would like to attach another RBK30 to the network but cost & availability seem to be prohibiti...
- Nov 30, 2022
AC1900 is not actually a product number. It is "Marketing Speak" for some mythical speed created by adding numbers together.
If it is similar to other WiFi extenders, then Yes. In addition to acting as a WiFi access point, the extender provides an Ethernet port that can be connected to a device or to a switch so that more devices can be connected.
In terms of "managing" devices, it depends on what that means. The central router will assign IP addresses to every device on the system and display all of them, either on the web interface Attached Devices page or on the Orbi app Connected Devices.
Devices will not roam seamlessly between the extender and the rest of the Orbi network (even if the extender uses the exact same WiFi SSID/password as the Orbi). For "things that do not move", such as garage door controllers, security cameras, refrigerators, etc. this is not an issue. However things like smartphones, tablet, laptops may "stick" to either the main network or the extender until the signal from it becomes impossible to use. i.e. they may get slower, and slower, and slower. Turning WiFi off and back on will cause the device to switch immediately to the more powerful signal.
Also, some extenders create fake MAC addresses for devices connected to them. I found that one extender (do not remember which one) hosed my carefully planned IP Assignment scheme because I based it on the actual hardware MAC addresses and the extender hid them. This doesn't really apply to the Orbi app, because the app does not allow assigning IPs to devices.
CrimpOn
Nov 30, 2022Guru - Experienced User
Fiat500
Dec 01, 2022Aspirant
Thanks. the device is an EX6410 (AC1900 Dual band WiFi Mesh extender) to boost existing WiFi. Important point you mention is that the transition between devices won't be seamless and I don't want that.. Thanks..
