fedxdelivered
May 26, 2017Tutor
Connecting Orbi's via LAN cable
Is it possible to connect two Orbi's via a LAN cable? I was reading and saw that the Linksys Velop has the capability to configure the ports to either a WAN or LAN. Reason I am asking is that my mo...
peteytesting
May 26, 2017Hero
fedxdelivered wrote:Is it possible to connect two Orbi's via a LAN cable? I was reading and saw that the Linksys Velop has the capability to configure the ports to either a WAN or LAN. Reason I am asking is that my modem and base unit are separated via a concrete wall from the satellite unit.
the answer at this stage is no , the response from netgear dev team is they are working on it but no time frame or certainty of release
also why bother with any mesh / DW system if you already have structured ethernet in place , just do what makes the most sense and run a wireless access point
- fedxdeliveredMay 26, 2017Tutor
The reason, why I am going with a mesh system, is that I want there to be just one network I can connect to. With access points/extenders, you need to set up a separate SSID and they don't boost the same signal strength as a router or a Orbi satellite. This is all from personal experience. I got the Orbi a couple of days ago and have noticed a significant difference. My train of thought was to have the two Orbi's connected via an ethernet cord and then boost the signal to the rest of the house from the satellite since the main Orbi is in a half surrounded concrete room.
- peteytestingMay 26, 2017Hero
fedxdelivered wrote:With access points/extenders, you need to set up a separate SSID and they don't boost the same signal strength as a router or a Orbi satellite. This is all from personal experience.
this is incorrect , how do you think offices / universities and schools do it
1 ssid name with many wireless access points
ethernet and wireless access points is and always will be the best way to do wifi anything else including mesh and dw systems like the orbi etc are a compromise
- fedxdeliveredMay 27, 2017Tutor
Right okay I agree with your first point.
Regarding your second point if I connect the Orbi Router with an Orbi Satellite via a LAN cord wouldn't that be the same if not better than an access point. I say this because an Orbi Satellite has multiple Ethernet ports. I don't see where the compromise is. I understand that connecting the two with a LAN cord sort of defeats the purpose of the 'mesh' system though.
