fedxdelivered
May 26, 2017Tutor
Connecting Orbi's via LAN cable
Is it possible to connect two Orbi's via a LAN cable? I was reading and saw that the Linksys Velop has the capability to configure the ports to either a WAN or LAN. Reason I am asking is that my mo...
fedxdelivered
May 27, 2017Tutor
Right okay I agree with your first point.
Regarding your second point if I connect the Orbi Router with an Orbi Satellite via a LAN cord wouldn't that be the same if not better than an access point. I say this because an Orbi Satellite has multiple Ethernet ports. I don't see where the compromise is. I understand that connecting the two with a LAN cord sort of defeats the purpose of the 'mesh' system though.
DukeSilver
May 27, 2017Star
Point is:
Dedicated 4x4 backhaul is a great solution to provide internet access to environments that do not otherwise have it - but you pay a premium for this solution that provides 2x2 wifi access.
If you have a wired backhaul environment, you can deploy 3x3 APs for less money that an Orbi.
