fedxdelivered
May 26, 2017Tutor
Connecting Orbi's via LAN cable
Is it possible to connect two Orbi's via a LAN cable? I was reading and saw that the Linksys Velop has the capability to configure the ports to either a WAN or LAN. Reason I am asking is that my mo...
peteytesting
May 30, 2017Hero
R5Copa wrote:Hi,
I saw that the RBS40 satelite has a Wan port.... So is this usable as a wired backhaul??
And compatible with the RBK50 kit??
nope , the rbs40 has 4 ethernet ports and NO wan port , the rbr40 has 1 x wan port and 3 x ethernet ports
so no its not usable as ethernet backhaul
R5Copa
May 30, 2017Tutor
You are right.... Did not look good enough i think.
Still staying hopefull that they make this future available true firmware.
Grz.
