ShelD
Oct 24, 2019Aspirant
Connecting RBR20 to Airport Extreme in "Bridge Mode"
Want to connect my Airport Extreme to my new Orbi RBR20. We are experiencing dropped signals and want to use the Extreme to help with signal strength. I know the Extreme needs to be set to "br...
Oct 24, 2019Guru - Experienced User
Is the Extreme being used as a router or do you want it to be a media wireless bridge from the Orbi to a wired device connected to the back of the Extreme. Wireless bridge on Apples Airport Extreme routers causes the router to turn in to a client thats only wirelessly connected to the Orbi wifi. This is only a connection between the two. Then you can connect wired LAN cable devices to the back of the Extreme in wirelss bridge mode.
There is no wireless extender signal that comes from the Extreme to other wireless devices to connect too when it's in bridge mode.
- ShelDOct 24, 2019Aspirant
I'm trying to prevent the dropped wi-fi signals we are experiencing from the Orbi.
Do not want to attach any devices directly to the back of the Extreme.
I believe what I want to do is to use the Extreme to assist with the strength of the wi-fi to prevent weak and/or dropped signals.
- FURRYe38Oct 24, 2019Guru - Experienced User
Bridge mode on the Extreme will not support what your trying to do. I don't know if AIrport Extreme supports Extender or any Repeater modes. Something to ask Apple about.
I would focus on the Orbi, if your having problems with wifi, lets see if we can narrow down whats happening there first, then later on, see if you need an extender.
What is the size of your home? Sq Ft?What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
Firmware V2.3.5.26
ISP: AT&T Aris U-Verse Wi-Fi is disabled for 2.5Ghz and 5.0Ghz
House is 2300sf Router and satellite are spaced approximately 30ft. Drywall, no concrete.
Dropped signals are occuring in rooms that are approximately 90ft to 300 ft from router. and 400ft from Satellite.
When you suggest the changes be made on channels and settings, are you refering to the Orbi router or the AT&T U-Verse?
