Gwaynee
Jul 07, 2023Aspirant
Connecting rbr50 sat to rbr40 router/?
hi. I have an rbr40 router with 2 sat. I got gifted rbr50 router with 1 sat.
whats the best way to hook all these up? Do<I create rbr50 router and add 2 rbr40 stats with 1 rbr50 sat? I have a 200...
michaelkenward
Jul 11, 2023Guru - Experienced User
Gwaynee wrote:
Unplugged modem. Reset router.
What is that modem?
When you started things up, did you do it in the correct order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Gwaynee
Jul 11, 2023Aspirant
Not exactly like that. It’s an ATT modem. U verse.
After following steps. Should I see RBR50 in app? And do,I do factory reset before this?
- michaelkenwardJul 11, 2023Guru - Experienced User
You would be better off ditching the app and using a PC and the browser graphical user interface (GUI) to set up your router. The app is a dumbed down way of setting up things.
If the RBR50 is up and running, the Nighthawk App should find it.
You might find it useful to read the manual for this thing.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
There may also be some helpful videos on what to do.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads. - michaelkenwardJul 11, 2023Guru - Experienced User
Which one? ATT has provided many different modems over the years. It sometimes like to supply modem/routers. That makes ir more complicated when you try to add another router.
What is Double NAT? | Answer | NETGEAR Supportand
How to fix issues with Double NAT | Answer | NETGEAR Support
- GwayneeJul 11, 2023Aspirant
5268 ac ATT modem
Gwaynee wrote:
5268 ac ATT modem
Is this it?
Pace 5268AC Wireless DSL Gateway Modem for AT&T U-Verse | ModemGuides
That is a "gateway", a modem router. That lands you in double NAT territory.
You need to set up your network accordingly, so that the "modem" does not fight with the Orbi router.
This might be useful:
att modem 5268ac bridge - Google Search
