AdrianM's avatar
AdrianM
Tutor
Feb 05, 2024
connecting RBR50 to ISP supplied modem/router using layer 2 bridge?
I'm not very knowledgeable with networking but hopefully someone can confirm that I'm heading in the right direction... For many years I've had an RBR50 plus three satellites happily connected to a VDSL  modem provided by a previous ISP.
As of today, I have a new ISP and when the hardware (THG3000) they sent me arrived it became clear that there was no bridge mode in their setup menu. I do need to keep their modem/router as it's the only way to connect our telephones via voip now that the POTs service is dicontinued. But I'm not prepared to put the Orbi into AP mode as I need the guest network. Naively connecting the Orbi WAN port to one of the THG3000 LAN ports taught me all about "double NATing" so I'm not going there again either.
So I began to research Layer 2 bridging and it seems like there are switches that can link two routers without any NAT or routing between them. Is this correct? I think the Netgear GS105Ev2 switch can provide this function. If I bought one and plugged the WLAN cable from the Orbi into one port and connected another to a LAN port on the THG3000 would that allow the Orbi to function as the router like it used to?
  • CrimpOn's avatar
    CrimpOn
    Sorry. The issue is that in router mode, the THG3000 creates a LAN for user devices, which creates the Double NAT.  Does your usage include the specific applications that are affected by Double NAT?  Such a device will not help.
    Putting an Orbi system into Access Point (AP) mode does not eliminate the Guest WiFi option.  What it does is eliminate the separation feature.  Rather than being placed into a separate IP subnet where they cannot communicate with each other or with devices on the primary network, they are placed in the same IP subnet.
    If you want the Guest network simply to have a method to allow "guests" to access the WiFi and to be able to change the password without affecting the dozens of WiFi gizmos around the house, then AP mode does what you want.
    If you want Guest network as some sort of security scheme, then no.
