AdrianM
Feb 05, 2024Tutor
connecting RBR50 to ISP supplied modem/router using layer 2 bridge?
I'm not very knowledgeable with networking but hopefully someone can confirm that I'm heading in the right direction... For many years I've had an RBR50 plus three satellites happily connected to a V...
CrimpOn
Feb 05, 2024Guru - Experienced User
AdrianM wrote:
Now I'm puzzled because I thought OSI model layer 2 network bridges acted as transparent connections between Ethernet segments. I thought they learned the MAC addresses of devices on each segment and forwarded traffic between them based on MAC. This way, all devices on both segments appeared to be on the same local network, without the need for any NAT or routing. You seem to be saying there will still be double NAT when using such a bridge?
Yes, a layer 2 bridge is equivalent to an Ethernet cable. It has no knowledge of layer 3, which where IP addresses exist. When the Orbi WAN port makes a DHCP request, the upstream router returns information:
- Use this IP address.
- Use this subnet mask
- The Gateway IP for any destination not on this subnet is MY IP ADDRESS.
- The default DNS IP is MY IP ADDRESS.
Both the Orbi WAN port and the upstream router are in the same IP subnet. It doesn't matter if they are connected with a physical cable, a layer 2 switch, a MoCA connection, a PowerLine connection. They all appear to both ends of the connection as an Ethernet cable.
This kind of sinks the idea of putting the Orbi into AP mode. (Lack of network separation).
I appreciate the fixation over Double NAT. What is not clear is if your internet use is affected by Double NAT. Thousands of customers simply unbox their new WiFi mesh system (Google Mesh, eero from Amazon, Asus, TP-Link, ... and Netgear), plug it into whatever thingy their ISP installed, and "off they go". In my neighborhood at least, a significant number of them do not even change the WiFi credentials from what was printed on the label. They have a Double NAT. Don't know what that is. And don't care.
Do you:
- Want access to LAN resources from the internet (access media server when not home? operate a public web site? want to view security cameras without using the vendor "cloud"?)
- Want to use a VPN tunnel to reach the Orbi router when not at home?
- Do internet gaming that requires you to forward ports through the router so that your home computer can at as a gaming server? i.e. the game will not work unless you forward ports?
All of those things are possible with a Double NAT, but are more complicated to set up and manage.
AdrianM
Feb 05, 2024Tutor
FURRYe38 will look into option 2 but ISP kit is extremely dumbed-down so not too hopeful about setting up DMZ.
CrimpOn Thanks again for the extra detailed explanation. Indeed I'm not in need of (or inclined) to access my LAN over a public IP or domain. So double NAT might be OK for me. What put me off is that when I tried it, the Orbi reacted by setting the subnet to 10.0.0.x and as I have lot's of home-brew IoT with baked-in IP's for various things running on local servers (there's around 30 reserved mappings for MAC to fixed IP to in the Orbi) and I don't want to re-flash a lot of embeded firmware. The Orbi looked like it was doing its best to honor the mappings by keeping the last byte of the IP though.
If I could somehow keep the same IPs handed out by the Orbi via DHCP then I'd be OK with this solution. I think I can change the IP address range for the ISP gateway DHCP and I did notice that it can also reserve specific IP's for connected device MACs. I just had to quickly revert to my old router/modem setup to keep the heating and lights going - so I hadn't looked into it further 🙄
- CrimpOnFeb 05, 2024Guru - Experienced User
The issue is the ISP router assigning 192.168.1.x to the Orbi WAN port. If the ISP router can be changed to use any other private subnet, then the Orbi will use 192.168.1.x
