AdrianM
Feb 05, 2024Tutor
connecting RBR50 to ISP supplied modem/router using layer 2 bridge?
I'm not very knowledgeable with networking but hopefully someone can confirm that I'm heading in the right direction... For many years I've had an RBR50 plus three satellites happily connected to a V...
AdrianM
Feb 05, 2024Tutor
FURRYe38 will look into option 2 but ISP kit is extremely dumbed-down so not too hopeful about setting up DMZ.
CrimpOn Thanks again for the extra detailed explanation. Indeed I'm not in need of (or inclined) to access my LAN over a public IP or domain. So double NAT might be OK for me. What put me off is that when I tried it, the Orbi reacted by setting the subnet to 10.0.0.x and as I have lot's of home-brew IoT with baked-in IP's for various things running on local servers (there's around 30 reserved mappings for MAC to fixed IP to in the Orbi) and I don't want to re-flash a lot of embeded firmware. The Orbi looked like it was doing its best to honor the mappings by keeping the last byte of the IP though.
If I could somehow keep the same IPs handed out by the Orbi via DHCP then I'd be OK with this solution. I think I can change the IP address range for the ISP gateway DHCP and I did notice that it can also reserve specific IP's for connected device MACs. I just had to quickly revert to my old router/modem setup to keep the heating and lights going - so I hadn't looked into it further 🙄
CrimpOn
Feb 05, 2024Guru - Experienced User
The issue is the ISP router assigning 192.168.1.x to the Orbi WAN port. If the ISP router can be changed to use any other private subnet, then the Orbi will use 192.168.1.x
