Dave_Di
May 11, 2020Follower
Connecting RBR50 to Plusnet 2704N Modem / Router
I have successfully connected an RBR50 and satelite system to my Plusnet modem / router. I recieve email and can browse internet when connected to Orbi network but when i tap on a link to a web site the system asked for passwords for the internet site. I've read that the Plusnet modem / router needs to act as a bridge to the RBR50 so that this doesn't happen but don't know how to make changes on Plusnet 2704N Modem / Router.
Also my recently purchased Apple Homepod will not connect to the internet through Orbi network but will do if i use it next to the Plusnet Modem / Router (with WiFi switched on).
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopContact the ISP or the Mfr of the modem for help and information regarding there product. Do a search online as well for briding information for the modem.
Dave_Di wrote:I have successfully connected an RBR50 and satelite system to my Plusnet modem / router. I recieve email and can browse internet when connected to Orbi network but when i tap on a link to a web site the system asked for passwords for the internet site. I've read that the Plusnet modem / router needs to act as a bridge to the RBR50 so that this doesn't happen but don't know how to make changes on Plusnet 2704N Modem / Router.
1 Reply
Couple of options,
