AnthonyKing
Oct 29, 2023Follower
connecting RBS50 to RBR350
Is it possible to connect an RBS50 satellite to an RBR350 router, and if so how? With thanks for any help you might provide. Anthony K
michaelkenward
Oct 30, 2023Guru - Experienced User
This might help:
Which Orbi routers and satellites are compatible? | Answer | NETGEAR Support
and
Are older Orbi WiFi satellites compatible with Orbi WiFi 6 Systems? | Answer | NETGEAR Support
The RBR350 is Wifi 6.
