Jonah868799
Feb 01, 2020Follower
Connecting ring doorbell with orbi RBK20
Trying to connect my ring doorbell to my router but cant find my router when trying to set it up
Feb 01, 2020Guru - Experienced User
What have you tried doing to fix it?
there's a bunch of posts on here about setting up orbi with IoT devices and doorbells.
Some regions found that the Ring doesn't work on channels >11.
https://community.netgear.com/t5/Orbi/Ring-Door-Bell/td-p/1144881
Some have luck with disabling the 5ghz ssid broadcast in the orbi.
Others cheat and just use a backup router running the same ssid/password as the orbi for setup. Once its setup, you remove the backup and turn the orbi back on. I've done this before when mesh first came out. I haven't needed to do it in a while though.
Which ring do you have specifically?
What firmware is on your orbi?
Which region are you in?
