tydeyo
Dec 28, 2019Follower
Connecting Smart Devices that are 2.4
I am trying to connect some "smart devices" like smart outlets, LaCrosse weather station and samsung dryer that need to connect with 2.4 wifi but my iPhone connects to 5 wifi. Does anyone know how to...
requ_moz
Apr 08, 2020Aspirant
Hi there,
I've seen that you had problems connecting your LaCrosse weather station to 2.4 GHz. I was in the same situation, but after couple of hours I have find the solution. People are talking about splitting the band in 2 and or other complicated things that make you give up. The Orbi is transmitting both signals/band at the same time and the devices are able to connect to it. In our situation the metro station and your cell phone have to be on the same band. In order to make your phone to connect to your 2.4ghz you have to be as far as you can from your router in order to force the phone to connect to 2.4 GHz which is a more stable and reaches further locations.
Therefore after getting a decent signal from your router, being again far away from it you are going to be able to pair with your station using the LaCrosse app. Easy as that.
Apr 08, 2020Guru - Experienced User
Netgear provides a simple mechanism to accomplish this:
Log into the Orbi web interface (http://orbilogin.net)
Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
Uncheck the box, "Broadcast SSID on 5G"
Click "Apply"
All devices that are currently connected to the Orbi will remain connected.
On the smartphone, go to wireless settings and "forget" the Orbi SSID
Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
Open the app and set up the 2.4G device.
Once the device is connected and working as it should, reverse the steps.
Check the "Broadcast" box and click "Apply"
"Forget" the Orbi WiFi. Search. Enter password. Connect.
requ_moz wrote:
Hi there,
- requ_mozApr 08, 2020AspirantI forgot to mention that when you do this press +- for 3 sec on your weather station to activate the wifi đ
