RickDean
Jan 05, 2020Follower
Connecting SmartLife 2.4ghz bulb
I am trying to add SmartLife bulbs but it requires 2.4 ghz and my Orbi has my phone connected at 5ghz. I think there is a way to change my Orbi to give the option of 2.4 versus 5 ghz versus now wher...
SW_
Jan 05, 2020Prodigy
Options to try to see which one works best for you:
- CrimpOnJan 05, 2020Guru - Experienced User
Could you please identify the manufacturer and model of this smart bulb?
(When I entered "smartlife" as a search term, I got zillions of hits and cannot figure out which one you might be working with.)
The reason for this question is that I made sort of a fool of myself recently by going through all sorts of maneuvers to get a Wyze smart plug to connect before I checked the Wyze web site, where the support FAQ told me exactly what to do. I did nothing to my Orbi, and the plug connected when my phone was connected to the Orbi at 5G.
