Sovby
Nov 20, 2021Aspirant
Connecting Synology Nas Server to Orbi RBK50
I am trying to connect a Synolgy server to my orbi router. On the box it says its an RBK50 but i dont see that in the list. I have contacted synology but i was wondering if there is a firewall on the...
CrimpOn
Nov 20, 2021Guru - Experienced User
RBK indicates a "Kit" consisting of one RBR50 (R for router) and one or more RBS50 (S for satellite). I agree that the drop down list of model numbers is disappointing (and distracting).
Sovby wrote:
wondering if there is a firewall on the router that i need to turn off.
Yes, the Orbi router contains a firewall (as do all routers), and No, there is no need to turn it off.
Sovby wrote:
I tried to connect to it through my windows pc but it dowsnt like the answers to the security questions. I'm as sure as i can be that im typing them in correctly, but it doesnt like the answers. i saw on another post someone suggested resetting everything and starting over but i'm still hopeful i dont have to do that.
Here you are definitely in a bind. When the Orbi is first taken out of the box:
- The WiFi credentials (name and password) are what is printed on the product label (bottom of the router), and
- The Orbi web administration credentials are "admin" and "password". Admin cannot be changed and the user is badgered into changing the password to something a bit more secure. There is also an opportunity to set up two Password Recovery questions which can be used to get into the router if the password is entered incorrectly three times in a row. Many users skip over that step and do not actually input answers to the questions. If this is the case, yes, a Factory Reset is the only way to get into the router.
The Synology error message is a result of the PC scanning the LAN and not getting a response from any Synology servers. If the Synology is connected to the Orbi router with an ethernet cable and powered on, something is wrong. I do not believe that you have do to anything on the router to attach the Synology. There are options which require forwarding ports on the router, but they are not required for local access. One key is the Synology software. Which version of D.S.M. is supposed to be on this Synology server?
- Aggie88Nov 20, 2021Apprentice
I have a Synology NAS (DS920+) attached directly to one of my RBS50 satelites via ethernet. I did not have to do anything to let it connect. Do you have any type of Orbi access control turned on?
I am running DSM version 6.2.3-xxxx on the NAS and 2.7.3.22 on the Orbi system
- CrimpOnNov 20, 2021Guru - Experienced User
That error message specifically mentioned D.S.M. 6.2.3 and clicking on a 'gear icon' in the upper right.
(I have no Synology server, so have never run any Synology software. Do you see this icon?)
