petermariana
Jan 19, 2020Aspirant
Connecting to internet
Bought this today but although I can connect my devices - phones and computers - to Orbi router, the router will not connect to the internet. My old router works just fine - so no issue with the mod...
Jan 19, 2020Guru - Experienced User
1. what firmware is on your orbi?
2. What model modem are you connecting to? Many are combo devices and orbi shows "no internet" even though there is because you're in a double nat. Not saying you are but its a potential.
- petermarianaJan 19, 2020Aspirant
Thanks for your help.
The modem is NBN provided ARRIS CMB200.
I'm sorry I don't know the router firmware version. Router is RBR 50 v2. I don;t have a double NAT setup.
Regards
- FURRYe38Jan 19, 2020Guru - Experienced User
Power OFF the isp modem for 30 seconds then back ON. Right after you turn ON the modem, factory reset the RBR and walk thru the setup wizard nd setup the RBR from scratch. Don't enable Circle or Armor.
What FW version are you using?
Swap out LAN cables between the RBR and modem. CAT6 is recommended.
Any Wifi Neighbors near by? If so, how many?Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
petermariana wrote:Thanks for your help.
Regards
- plemansJan 19, 2020Guru - Experienced UserI take it you mean the CM8200?
FURRYe38 had good advice. I'd follow that first.- FURRYe38Jan 20, 2020Guru - Experienced User
That would be the SB8200. There isn't a CM8200 model modem.
