einarso's avatar
einarso
Guide
Jan 23, 2019
Connecting via VPN does not change my IP/location
One of the main reasons I choose Orbi as my home network solution, was to have VPN functionality.  I travel a lot, and there are websites/apps/services that require me to be connected from my home network to have full functionality (like getting all channels from my TV-provider).
I tried the service this weekend, and found out that the VPN service does not change my IP, so basicly it does not channel my internet traffic through my home router.  Is this really supposed to work like this?  What is the use of VPN-functionality on a home router if not to connect traffic through the home network?
Is there something wrong with my setup, or does Orbi VPN functunality simply suck?
  • Whats your VPN Setting for "Clients will use this VPN connection to access:"?
    Make sure it's on "All sites on the Internet & Home Network" - You may need to redownload the configuration after you changed the settings.
    If this didn't do the trick, what plattform are you using?  Have you tried a different configuration?
    • einarso's avatar
      einarso
      Guide
      Thank you mrmstn.  Changing from "Auto" to "All sites on the Internet & Home Network" solved the problem on my iOS devices.
      I am still struggling with the Mac, but I think the problem there is correct installations of the konfiguration files.  Starting the VPN on the mac gives me repeating messages in the log "write to TUN/TAP: Input/output error (code=5) and my connection to the internet disrupts.  I get an error message telling me the IP did not change.
      When I try to install the VPN configuration in Tunnelblick, the Orbi gives me 5 files, but I can only drag the client.conf file to Tunnelblick.  It does seem to install correctly.  The config.ovpn file after installation states:
      client
      dev tap
      proto udp
      remote xxx.mynetgear.com 12974
      resolv-retry infinite
      nobind
      persist-key
      persist-tun
      ca ca.crt
      cert client.crt
      key client.key
      cipher AES-128-CBC
      comp-lzo
      verb 5
      script-security 2
      up dhcp-client-request.sh
