redvalleybpy
Jan 02, 2020Follower
Connecting with BT SmartHub
Hi Just bought a Orbi Whole Home WiFi System from Costco naively thinking it was an easy plug and play Wi-Fi extender...MESH network is running to both satellites but router is showing offline despi...
Its probably because you're running them both in router mode.
https://kb.netgear.com/30186/What-is-Double-NAT
either try placing the bt smarthub in modem only/passthrough mode or placing the orbi in AP mode.
If you go the router of placing the orbi in AP mode, make sure to disable the wireless on the bp smarthub
