georggeissler
Mar 11, 2024Aspirant
Connection between attached devices drops (no ping possible)
I have a Orbi AC3000 setup with Hardware Version RBR50 Firmware Version V2.7.5.4 GUI Language Version V1.0.0.423 Operation Mode Router And three satellites: RBS50 all on FW V2.7.5.4 Connect...
Mar 11, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
- CrimpOnMar 11, 2024Guru - Experienced User
What is the make/model of this WiFi camera?
Does it appear in the list of Attached Devices?
What prompted the desire to ping the camera?
Thanks
- georggeisslerMar 16, 2024Aspirant
Hi CrimpOn
>> Reolink (several models)
>> But I has same issue with Android tablet the other dayDoes it appear in the list of Attached Devices?
>> yes, and the device can be reached from my laptop e.g. which is connected to the router
>> troubleshooting to verify connection
Thanks
Thanks for your respose FURRYe38
>> issue is on local LAN/WIFI only. Internet works fine.How many RBS are deployed?
>> 3
>> All RBS show good connection (green)
>> devices right next to an RBS are not reachable tooWhat is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰>> distance is below 30ft
>> not sure, RBSs are always on.
>> yes
>> 2.4GHz Channel:06
5GHz Channel:48
