georggeissler
Mar 11, 2024Aspirant
Connection between attached devices drops (no ping possible)
I have a Orbi AC3000 setup with Hardware Version RBR50 Firmware Version V2.7.5.4 GUI Language Version V1.0.0.423 Operation Mode Router And three satellites: RBS50 all on FW V2.7.5.4 Connect...
Mar 11, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
CrimpOn
What is the make/model of this WiFi camera?
Does it appear in the list of Attached Devices?
What prompted the desire to ping the camera?
Thanks
- georggeisslerMar 16, 2024Aspirant
Hi CrimpOn
>> Reolink (several models)
>> But I has same issue with Android tablet the other dayDoes it appear in the list of Attached Devices?
>> yes, and the device can be reached from my laptop e.g. which is connected to the router
>> troubleshooting to verify connection
Thanks
