Pattywack
Apr 23, 2020Aspirant
Connection between Router and satelite has changed from 5g to 2,4g all of a sudden.
Hi guys I'm looking for some help with my setup. I live in a 100m2 two story house. My internet backhaul is in the livingroom on the 1st floor while my satelite is located in the hallway on the s...
Apr 23, 2020Guru - Experienced User
There is a recent v16 version of FW that seems to be better for users you might want to try:
- PattywackApr 23, 2020Aspirant
I'm currently at version 2.5.1.8. The distance between the two units is probably between 15-20 feet.
I have a question about beamforming. As to my understanding the router focus more of sending the signal in "one" direction instead of 360 degrees. What is the deciding factor for what direction is chosen?
I'll give the other settings a try if the radar thing is not the reason :-)
Thanks for the torough answer.
Edit: We do have neighbours on each side of the house.
- FURRYe38Apr 23, 2020Guru - Experienced User
https://kb.netgear.com/23503/Beamforming-FAQs
https://www.howtogeek.com/220774/htg-explains-what-is-beamforming-on-a-wireless-router/
https://en.wikipedia.org/wiki/Beamforming
What channels are the neigbors using?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- PattywackApr 24, 2020Aspirant
Thanks for the reply FURRYe38. I tried all of the settings you told me to and nothing have really helped. Just to test it, I tried moving the satelite to the same room, within 5feet of the router and the connection type is still 2,4G.
The modem is a Sagecom fast 3890v3 modem provided by my ISP. Could this be something regarding me not having a static IP?
I really new into network configuring and setup so sorry for my slow handling and lack of knowledge.
I'm lost in what to do now. I don't know why the satelite wont do a 5G backhaul connection to the router..
Edit: I have updated both BRB and BRS to 2.5.1.16 aswell.
