Pattywack
Apr 23, 2020Aspirant
Connection between Router and satelite has changed from 5g to 2,4g all of a sudden.
Hi guys I'm looking for some help with my setup. I live in a 100m2 two story house. My internet backhaul is in the livingroom on the 1st floor while my satelite is located in the hallway on the s...
Apr 23, 2020Guru - Experienced User
There is a recent v16 version of FW that seems to be better for users you might want to try:
Pattywack
Apr 24, 2020Aspirant
Thanks for the reply FURRYe38. I tried all of the settings you told me to and nothing have really helped. Just to test it, I tried moving the satelite to the same room, within 5feet of the router and the connection type is still 2,4G.
The modem is a Sagecom fast 3890v3 modem provided by my ISP. Could this be something regarding me not having a static IP?
I really new into network configuring and setup so sorry for my slow handling and lack of knowledge.
I'm lost in what to do now. I don't know why the satelite wont do a 5G backhaul connection to the router..
Edit: I have updated both BRB and BRS to 2.5.1.16 aswell.
