T-E-R
Apr 24, 2020Tutor
CONNECTION BETWEEN THE ROUTER AND SATELLITE
Is the blue light on the satellite supposed to stay on if it is connected or does it turn off. I have moved the satellite closer and closer to the orbi router and it comes on but then goes off. The...
Retired_Member
Apr 24, 2020- T-E-RApr 24, 2020Tutor
RBS20
So, bottom line. is it ok if the light pulsates blue and then goes off?
It stayed on pretty much all day. This morning it was still on. How can I figure out if something and what is wrong?
- Retired_MemberApr 24, 2020
T-E-R wrote:It stayed on pretty much all day. This morning it was still on. How can I figure out if something and what is wrong?
I would unplug it and let it reset. Not factory reset, just a simple unplug. At the same time, unplug your modem, get that back online and then plug in the Orbi
