T-E-R
Apr 24, 2020Tutor
CONNECTION BETWEEN THE ROUTER AND SATELLITE
Is the blue light on the satellite supposed to stay on if it is connected or does it turn off. I have moved the satellite closer and closer to the orbi router and it comes on but then goes off. The...
Retired_Member
Apr 24, 2020T-E-R
Apr 24, 2020Tutor
RBS20
So, bottom line. is it ok if the light pulsates blue and then goes off?
- T-E-RApr 24, 2020Tutor
It stayed on pretty much all day. This morning it was still on. How can I figure out if something and what is wrong?
- Retired_MemberApr 24, 2020
T-E-R wrote:It stayed on pretty much all day. This morning it was still on. How can I figure out if something and what is wrong?
I would unplug it and let it reset. Not factory reset, just a simple unplug. At the same time, unplug your modem, get that back online and then plug in the Orbi
