T-E-R
Apr 24, 2020Tutor
CONNECTION BETWEEN THE ROUTER AND SATELLITE
Is the blue light on the satellite supposed to stay on if it is connected or does it turn off. I have moved the satellite closer and closer to the orbi router and it comes on but then goes off. The...
PeytonBrandt
Apr 24, 2020Star
I'm pretty sure the blue light indicates that it's syncing settings with the main router. Once it's done syncing, the light will turn off and there should be no lights on either devices during normal operation.
T-E-R
Apr 24, 2020Tutor
OK, understand. So the white light should NOT stay on the router? It is right now so there is something wrong?
- PeytonBrandtApr 24, 2020Star
Correct. No lights means no problems.
- Retired_MemberApr 24, 2020
T-E-R wrote:OK, understand. So the white light should NOT stay on the router? It is right now so there is something wrong?
how long has it been on? Sometimes it may take several minutes to settle down
