T-E-R
Apr 24, 2020Tutor
CONNECTION BETWEEN THE ROUTER AND SATELLITE
Is the blue light on the satellite supposed to stay on if it is connected or does it turn off. I have moved the satellite closer and closer to the orbi router and it comes on but then goes off. The...
T-E-R
Apr 24, 2020Tutor
OK, understand. So the white light should NOT stay on the router? It is right now so there is something wrong?
PeytonBrandt
Apr 24, 2020Star
Correct. No lights means no problems.
