SachaLewin
Dec 14, 2020Aspirant
Connection constantly crashing, tried factory resets, other configurations, but nothing works
Hello, I recently bought an Orbi setup with 1 router and 2 satellites because my PLC adapters were losing connection too often, and speed wasn't great (400/20 at access point, 80/15 at PLC). It w...
tucsontico
Dec 14, 2020Virtuoso
Please check the firmware version on all three pieces of your ORBI system. Be absolutely certain they are the same version. If not, update the satellites first, then the router. Do a factory reset and then reconfigure from scratch. DO NOT use a backup config file to re-initialise your system.
Also, looking at your layout, I believe your satellite #1 is too close to the router. Try to move that satellite to get about 10 meters between the router and your #1 satellite. Then adjust the #2 satellite to be about 10 meters from the #1 satellite. If all this doesn't work, try eliminating one satellite.
Good luck!
SachaLewin
Thanks for the reply. They are all the same version. The problem is that if I remove the satellite 2, I can't connect with ethernet on my PC that doesn't have Wi-Fi, and using only that satellite results in poor connection. Perhaps I should buy a wifi adapter for the PC and stop the satellite 2.
