SachaLewin
Dec 14, 2020Aspirant
Connection constantly crashing, tried factory resets, other configurations, but nothing works
Hello, I recently bought an Orbi setup with 1 router and 2 satellites because my PLC adapters were losing connection too often, and speed wasn't great (400/20 at access point, 80/15 at PLC). It w...
DarkNet
Dec 14, 2020Apprentice
FWIW, I have daisy-chain unchecked on my system of 1 RBR20 and 2 RBS20s. I think it was contributing to drop out issues. I also turned down the transmission power so as not to peg-out communication to the satellites.
SachaLewin
Thanks for the reply, I will try unchecking daisy-chain. How did you turn down transmission power? I'm a bit lost on the web interface.
Thanks
