BiffTanner
Feb 22, 2017Follower
Connection Drops Every 30 seconds
Hello - I just set up my Orbi. Signal strength is wonderful but the connection drops every 30 seconds or so. It is very annoying.
Anything I should try before I return the product?
Thanks!
1 Reply
- Streak2Master
Go to advanced settings and try and disable.
Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
MU-MIMOAlso, try and reduce the 2.4Ghz power from 100% down to say 50%. If that works then try and find a happy medium.
