HCC202
Apr 09, 2018Star
Connection Failure on Speed Test
I did a facory reset of my system about two weeks ago and loaded the new firmware for the system which seems to be working better. I have been able to perform spped tests on the system through the Or...
Apr 09, 2018Guru - Experienced User
I would notify NG support. Maybe something going on on with the app. Maybe due for an update.
Guanadus
Apr 09, 2018Tutor
The modem router is connected too in bridge mode.
Model MitraStar GPT-2541GNAC (HGU) from MOVISTAR (Spain).
The problem is with the Orbi app on IOS & Android (both)
The problem is also in orbilogin.com in the advance setting > speed test.
Note that the error stated yesterday, previously worked fine in all systems
Thanks
Thanks
- FURRYe38Apr 09, 2018Guru - Experienced User
