HCC202
Apr 09, 2018Star
Connection Failure on Speed Test
I did a facory reset of my system about two weeks ago and loaded the new firmware for the system which seems to be working better. I have been able to perform spped tests on the system through the Or...
Guanadus
Apr 09, 2018Tutor
The modem router is connected too in bridge mode.
Model MitraStar GPT-2541GNAC (HGU) from MOVISTAR (Spain).
The problem is with the Orbi app on IOS & Android (both)
The problem is also in orbilogin.com in the advance setting > speed test.
Note that the error stated yesterday, previously worked fine in all systems
Thanks
Thanks
Apr 09, 2018Guru - Experienced User
I would notify NG support. Maybe something going on on with the app.
