HCC202
Apr 09, 2018Star
Connection Failure on Speed Test
I did a facory reset of my system about two weeks ago and loaded the new firmware for the system which seems to be working better. I have been able to perform spped tests on the system through the Or...
Orbiuser12
Apr 09, 2018Aspirant
Same issue , speed test failed on mobile app. I ran it in pc connected to Orbi router and worked fine
howens1
Apr 10, 2018Aspirant
Speed test fail ,I changed cable , rebooted , confirm updates, when you pay $500, you don't expect problems in less than 8 months, thank god for the community, all manufacturer suck with service.
Orbiuser12 wrote:Same issue , speed test failed on mobile app. I ran it in pc connected to Orbi router and worked fine
