HCC202
Apr 09, 2018Star
Connection Failure on Speed Test
I did a facory reset of my system about two weeks ago and loaded the new firmware for the system which seems to be working better. I have been able to perform spped tests on the system through the Or...
Guanadus
Apr 09, 2018Tutor
Same problem from yesterday to me. I have used IOS app without any problem and also if I try to do the speed test from the Web access (Orbilogin) and I receive the same error.
I have uninstall the app & install it again in my iphone & ipad but the same error appears.
I have tried too a android smartphone and same problem.
On the other hand, I have had also a magent ligth in my router today, hopefully I fixed it.
Last firmware installed. (v2.0.0.56)
Thanks
TreborNewob5
Apr 17, 2018Guide
We just have to wait! Emailed Netgear App Support about my issue and was Emailed back with the statement that Netgear are aware and are working with Ookla to fix this problem!
That was great to hear but why is there still no mention about all of this on Netgears Main support page?
Still hold the opinion that Netgear as a Global Company just does not care about it's customers.
So problem still not fixed👺
- j_t_gApr 17, 2018Guide
The last commenter is unfortunately correct. I've tried to obtain multiple updates, but there are none. The most I have heard is that Netgear is actively working with Ookla to resolve the problem. You wouldn think they would have been able to resolve the issue in a week, but I guess the issue must be more complicated than it seems from the outside. One interesting side effect of this issue is that if you've never setup advanced QoS on your router and want to you appear to be out of luck until the speed test works (at least via the Web admin). They require the speed test to run before you can actually get to the setup parameters. I haven't figured out a way around this. Hopefully, Netgear will be able to fix the problem soon as many of us have been impacted by this issue.
