HCC202
Apr 09, 2018Star
Connection Failure on Speed Test
I did a facory reset of my system about two weeks ago and loaded the new firmware for the system which seems to be working better. I have been able to perform spped tests on the system through the Or...
Guanadus
Apr 18, 2018Tutor
I have tested the speed test in my iPhone and works again.
On orbilogin working too
It seems the problem has been fixed
Thanks
Thanks
PaulK617
Apr 21, 2018Star
Now my problem just got worse. Speedtest is fixed but losing connection on my Nest thermostat, then garage opener, now Nest thermostat went offline again. Three times in 3 days. I’ve rebooted the router for a temporary fix. I have about 20 devices. This is even more frustrating. I could live with using Speedtest outside of Orbi. Anyone else have this issue after Speedtest fix?
- j_t_gApr 21, 2018Guide
PaulK617No, I haven't experienced any issues since the Speed Test problem was resolved. My nests, Hue, and Echos are all connected. I'm not sure what firmware you're using - is it 2.1.3.4? The reason I ask is that my Orbi never detected this update, and I had to go to the support page to download and manually apply the latest version. If you're using an older firmware, give that a try. Another thing that might be worth trying is to change the channels you're using for both 2.4 and 5.0 gHz. Maybe you're coincidentally picking up from new interference from something else. Otherwise, I'm sorry to say you might need to try to open a support ticket.
